Use the following procedure to display trace information for CFM.
Use trace to observe the status of a software module at a certain time.
For example, if you notice a CPU utilization issue (generally a sustained spike above 90%) perform a trace of the control plane activity.
Use the trace level 120 <0–4> command to trace CFM module information, including CLI, instrumentation, show config, and platform dependent code. The CFM module ID is 120.
Use the trace cfm level <0–4> command to trace platform independent code and CFM protocol code.
Caution
Risk of traffic loss
Using the trace tool inappropriately can cause CPU lockup conditions, loss of access to the device, loss of protocols, and service degradation.
Switch:1>enable Switch:1#configure terminal Switch:1(config)# clear trace Switch:1(config)# trace cfm level 3 Switch:1(config)# trace shutdown Switch:1(config)# show trace cfm ================================================================================ CFM Tracing Info ================================================================================ Status : Enabled Level : VERBOSE Switch:1(config)#trace level 120 3 Switch:1(config)# save trace Switch:1(config)# trace grep error Switch:1(config)#trace grep 00-1A-4B-8A-FB-6B
The following table defines parameters for the trace command.
Variable |
Value |
cfm level [<0-4>] |
Starts the trace by specifying the level.
filter |
Configures a filter trace for a file or module. |
flags |
Configures trace flags for IS-IS or OSPF. |
grep [WORD<0-128>] |
Searches trace results for a specific string value, for example, the word error. Performs a comparison of trace messages. |
level [<Module_ID>] [<0-4>] |
Starts the trace by specifying the module ID and level.
route-map |
Enables or disables the trace route-map. The values are on and off. |
screen {disable|enable} |
Enables the display of trace output to the screen. |
shutdown |
Stops the trace operation. |
spbm isis level [<0-4>] |
The default is 1, very terse. |
The following table defines parameters for the save trace command.
Variable |
Value |
file WORD<1–99> |
Specifies the file name in one of the following formats:
/mnt/intflash is the internal flash of the CPU. /mnt/extflash is the external flash of the CPU. |
